Just wondering if anyone knows where I can get a kit or the parts to reverse the front sway bar from the front to the rear? Alan Ward used to make a set up with solid bushings for racing, where the rear sway bar was supported from extended steering limit bars, instead of the front cross member. The bolts would strip out under hard corners, hence the modification.
Thanks!
Thanks!
