The photos are showing an older repair from PO, considering that sometimes in the past the support was broken. Left side however is intact. I consider that this is inappropriate as top end of shock absorber's shaft almost touching the plate above. Also it is obvious that shaft is hitting occasionally the plate as it is already dented upwards. Any comments or suggestions how to fix it or how it should be?
