Are the 1600 spec's for the front suspension adjustments the same as the 1750/2000? All I have are the specs for the latter. Client's GTV needs to return to the frame shop and I want to send along the specifications to (hopefully) avoid a third time.
Later I'm going to be listing a wanted: need left and right 1600 GTV wheel hub units. Must be known that they are straight and not from a car with serious front end damage.
I Installed a new cast wheel on the least damaged side of the GTV and it wobbled about an 1/8th of an inch when turned. I installed the same wheel on a Spider and it ran true.
