1 - 2 of 2 Posts
i am looking for a part,really do not want to go to local shop here, they tryed to charge me one time $100.00 for a head gasket, so i am looking for a part. on the lower a-arm there is a lock washer between the "d" washer and the nut that holds the lower a-arm on, or can i use locktight? for this.thanks
It's not a simple process to set up the inner lower A-arm bushings, if that's what you're referring to. Kind of hard to tell for sure. But yes, the bent-over lock washers are the way to go; I wouldn't loctite.
1 - 2 of 2 Posts
