Hello guys,
It seems I am not able to get my Verde bar that is in Las Vegas, so I am searching for another one (24mm front bar) as I have someone coming to Peru who can bring it down here for the alfetta gt on January. Let me know if you have one lying around.
You try calling APE in Tracy? That's where I got mine.
There are 2 sizes of Verde bars, by the way. The 22mm early and 24mm late version. Be sure you get the one you're seeking by getting measurements because not everyone will be aware of the early vs. late version. If you have a stock suspension on a pre-85 GTV6, a 24mm bar will potentially cause problems at the front sheetmetal mounting area.
I also suggest calling APE in CA (good suggestion, Tom).
Thanks for the hint Tom. Rob the car has: 25.4mm torsies, match springs, 20mm front and rear anti roll bar (stock), Spax shocks, poly bushes everywhere except for the shocks. I read that going beyond 24mm will cause troubles, seems that I should use reinforcement plates just in case ;)
I just looked and I have a 24mm front bar (measured it to be sure). Not sure how much it would cost to ship to Peru.
Kevin
