ALFA ROMEO -
FRONT WHEEL
1989-1959 Spider
Seal (inner) ......................................................... 224100[2]
Bearing Assy (inner) .......................................... 30206M[2]
Bearing Assy (outer) .............................................32303[2]
1989-1987 Milano
Seal (inner) ............................................................. 1973[2]
Set (inner) ..............................................................SET8
Set (outer) ..............................................................SET2
1986-1981 GTV6
1981-1974 Veloce - GT, Spider
Bearing Assy (outer) ..........................................32304M[2]
1981-1972 GTV
Bearing Assy (outer) .............................................30203[2]
1979-1977 Sport Sedan
Seal (inner) ......................................................... 494117[2]
Set (inner) ..............................................................SET1
Set (outer) ..............................................................SET1
1976 Alfetta Series
1975 Alfetta Series
Set (inner) ..............................................................SET4
1974 2000 Berlina
1974-1970 Berlina
1971-1970 1750 Berlina
1969-1962 Giulia
1968-1963 2600
Bearing Assy (inner) .......................................... 30207M[2]
1966-1958 2000
1962-1957 Giulietta: production from
12/1957 on
Bearing Assy (inner) .......................................... 30305M[2]
FRONT WHEEL (cont.)
1957-1955 Giulietta: production thru 11/1957
Bearing Assy (outer) .............................................30303[2]
REAR WHEEL
1989-1976 Spider
Seal .................................................................... 223035[2]
B e a r i n g ................................................................ 88107[2]
1989-1987 Milano
Seal .................................................................... 224210[2]
B e a r i n g .............................................................. 513106[2]
1986-1981 GTV 6
1981-1972 GTV
B e a r i n g .............................................................. 513102[2]
1979-1977 Sprint Veloce
1976-1975 Alfetta Series
1974-1970 2000 Berlina
1970-1966 Spider
B e a r i n g ................................................................ 88508[2]
1969-1962 Giulia
1965-1958 1900 Series
1962-1955 Giulietta
REAR AXLE
D i f f e r e n t i a l
1989 Spider 2000, Graduate,
Quadrifoglio, Veloce
C o n e / C u p ................................................. 28150-28300[2]
1989-1987 Milano
S e t ...................................................................... SET45
1988-1976 Spider 2000, Graduate,
1986-1981 GTV6
S e t ...................................................................... SET37
2 [ ] Indicates Quantity Required; Set Components Listed Inside Rear Cover;
Mfg./Year Model & Location Part No Mfg./Year Model & Location Part No
ALFA ROMEO - 164 (cont.)
REAR AXLE (cont.)
Differential (cont.)
1981-1972 GTV / GT Veloce
1976-1975 Alfetta Coupe, spider
C o n e / C u p ....................................... LM29749-LM29710[2]
1974-1970 Berlina
P i n i o n
1989-1987 Milano
Cone/Cup (inner) ............................HM89446-HM89410
Cone/Cup (outer) .................................M88048-M88010
1988-1976 2000 Spider, Berlina, Graduate,
Quadrifoglio
1986-1983 GTV6
Cone/Cup (inner) ......................HM801346X-HM801310
Cone/Cup (outer) ............................HM89446-HM89410
1964-1955 Giulietta Series
3-SPEED AUTOMATIC TRANSMISSION
Torque Converter
1983-1980 ZF3HP22
Seal .................................................................... 224010
Kwik Slv (Opt Rpr) ........................................KWK99157
Rear Seal/Ext. Housing
1983-1980 ZF3HP22
Seal ......................................................................3459S
B e a r i n g .............................................................. 107WB
4-SPEED AUTOMATIC TRANSMISSION
Torque Converter
1989-1984 ZF4HP22
Seal .................................................................... 224052
1989-1984 ZF4HP22
CLUTCH
Release Bearing
1989-1976 Spider 2000
Bearing Assy ..................................................... 614100
1989-1975 2000
1989-1987 Milano
Bearing Assy ..................................................... 614102
1986-1981 GTV6
1985-1976 Spider Veloce
Bearing Assy ..................................................... 614101
CLUTCH (cont.)
Release Bearing (cont.)
1977-1976 Alfetta Coupe, spider
ALTERNATOR
1987-1965 Bosch 35 amp
Bearing (rear end) .................................................. 201S
1987-1965 Bosch 45 amp
Bearing (drive end) .................................................203S
1987-1965 Bosch 55, 65 amp
1977-1975 Marchal
Bearing (drive end) ...............................................203FF
Bearing (rear end) ............................................... 200CC
GENERATOR
1967-1959 Marelli DN44AE
Bearing (drive end) ..............................................202AG
Bearing (rear end) ................................................201AB
1962-1959 Marelli DN59C
Bearing (drive end) ...............................................202FF
Bearing (rear end) ............................................... 201CC
1962-1959 Bosch
CRANKSHAFT REAR SEAL
4 Cylinder
1989-1980 1962cc/2.0L
Seal .................................................................... 228480
Kwik Slv (Opt Rpr) ........................................KWK99328
6 Cylinder
1989-1981 2492cc/2.5L, 2959cc/3.0L
TIMING COVER
4 Cylinder
Seal .................................................................... 223520
Kwik Slv (Opt Rpr) ........................................KWK99139
6 Cylinder
[ ] Indicates Quantity Required; Set Components Listed Inside Rear Cover; 3
FRONT WHEEL
1989-1959 Spider
1989-1987 Milano
1986-1981 GTV6
1981-1972 GTV
1976 Alfetta Series
1975 Alfetta Series
1974 2000 Berlina
1974-1970 Berlina
1969-1962 Giulia
1968-1963 2600
1966-1958 2000
12/1957 on
FRONT WHEEL (cont.)
REAR WHEEL
1989-1976 Spider
1989-1987 Milano
1986-1981 GTV 6
1981-1972 GTV
1970-1966 Spider
1969-1962 Giulia
1962-1955 Giulietta
REAR AXLE
1989-1987 Milano
1986-1981 GTV6
REAR AXLE (cont.)
1974-1970 Berlina
P i n i o n
1989-1987 Milano
Quadrifoglio
1986-1983 GTV6
Torque Converter
1983-1980 ZF3HP22
1983-1980 ZF3HP22
Torque Converter
1989-1984 ZF4HP22
1989-1984 ZF4HP22
CLUTCH
Release Bearing
1989-1975 2000
1989-1987 Milano
1986-1981 GTV6
CLUTCH (cont.)
ALTERNATOR
1977-1975 Marchal
GENERATOR
1962-1959 Bosch
4 Cylinder
6 Cylinder
TIMING COVER
4 Cylinder
6 Cylinder
