I have a fresh long block to sell. It is a 1600 unnumbered block (i.e. service block) with a two litre crank, clutch etc. This motor was built by Lee Midgley some time ago but had never been fired. I finished the motor by putting a set of 40 mm webers, euro cams (148's) water pump etc,etc,. Has a spin on filter adapter though the original cartidge holder can go with it. Runs 180 lbs compression(cold) all the way across. Added Marelli Plex also. I dont know exactly what Lee did internally as I did not take the motor down. Looking down the spark plug holes the valves all look new. I did replace the front and rear crank seals as the motor sat for quite some time though I did rotate the crank regularly. Runs beautiful but needs a more aggressive ignition curve. Only 30 minuets run time on it for break in. You can hear it run as i have it on a test stand. $5500.00 firm. Complete with trans. Illness forces sale of all my Alfa stuff. Engines, transmissions, differentials (including a 2 litre rear end rebuilt by Midgley and never installed) Fuel injection pumps, Carbs etc, etc.
Please call me at 951 927 7438 and ask for Tony. I prefer to talk on the phone as I will be overwhelmed by emails.
http://img.photobucket.com/albums/v356/alphaalfa1/motor002r.jpg
http://img.photobucket.com/albums/v356/alphaalfa1/motor001r.jpg
