1 - 20 of 38 Posts
Ciao Steve
I wish i can post pictures of my new baby but i don't have enough posts to be allowed to do that yet.
I appreciate your input and help
Start your story board on your 91 164L
Ciao Steve
You are only 5 away. Tell us about it and work your way up to 10 by adding to this thread for your story board on the 91 164L you just got.
You have any good history on when timing belt was changed and mileage on it? NUMBER 1 Item to change if no good believable history!
Steve
I asked the Ebay dealer where i bought the car if timing belt was changed,he said he didn't know.(mileage on my baby is 132000) so i am hoping it was changed before the 100000 mark?
All i can tell you is that i drove it around a bit,got the oil changed and added premium gas in it.
But like I said,temperature started going up,looks like fan is not kicking in at all.
Hopefully,tomorrow,the mechanic i found will be able to tell me more about any issues.
For 91,the body is in great shape,the interior as well,no rips,dents or fading.
Keeping my fingers crossed :)
Also,since nobody could point a good Alfa Romeo mechanic in Atlanta, can i advertise the one i found if i see he is good?
he primarily works on Fiat cars .
You need a timing belt change pronto! This is not a 100,000 timing belt car. We change them at 35,000 miles along with water pump and then water pump again at second belt change.
Alfa originally tired to say change TB at 50,000 miles and they were having belts fail before that and bending valves.
Trying to scare you because there have been so many 164 engines with timing belt issues.
Pirate, I would contact the Alfa Romeo Club of Atlanta. They should be able to help with a good local mechanic.
Welcome to the Board, Pirate...
Yes, do let us all know how things work out at our mechanic's...
Hope to see some pics when your post count allows!
What attracted you to the 164, if I may ask? We all love to hear owners' Origin Stories..
Cheers,
- Art
Mechanic
I am following your advice and told mechanic to change the TB and water pump.
It also needs boots for tie end rods and sensor for radiator fan.
It will be ready to roll on Wednesday.
Thank you for your advice.
Mechanic
Cheers,
- Art
Mechanic seems to know his stuff.
As for me,my uncle in Italy had an alfa 164,loved it when i went to visit and i always wanted one,but back then ,being a struggling single dad,kids came first,could not afford one until now.
I saw this one on Ebay,
Discussion Starter #13
Was seller was in/near Daytona Beach?
Discussion Starter #15 (Edited)
Parts list for changing timing belt and water pump on 12v V6
Parts list for changing timing belt and water pump:
I did not include upper or lower radiator hoses which have to be disconnected to change timing belt and/or water pump.
You need to download cam timing pdf template so mechanic does not have to remove valve covers to verify cam timing against TDC mark on crankshaft pulley.
http://www.alfabb.com/bb/forums/7959449-post12174.html
Discussion Starter #17 (Edited)
Steve
I saw that ,thank you :)
I added pictures of parts plus template pix and pictures of timing belt,serpentine belt, power steering belt and alternator belt.
Here is more complete parts lists with upper/lower hoses and belts included: Parts list for doing 12v timing belt , water pump and hose change.
AR p/n Nomenclature
60562106 timing belt
alt Dayco 95120 or 94423 size 134SX254
60588421 Tensioner , mechanical
60555347 water pump* alt 71713045 NOW 71737989
60777086 gasket w/p alt 60507414
60808356 hose sleeve to rear head NOW 60573501
60808355 hose sleeve to front head ALT 10129086 NOW 60604023
60615713 gasket, metal lower to pump (paper) Alfa paper gasket p/n 60552316
15248711 bolts, thermostat M7x55mm long
60507415 gasket, thermostat upper
60507416 gasket, thermostat mid housing
60559862 thermostat neoprene
60512902/60574777 belt, PS Dayco 15310 15529
60513889 belt, alt 5050273 Dayco 15527
60571636 belt, w/p 5070425 Dayco 15525
60507327 o-ring cam pulley hub (2) if needed
60610985 seal, cam pulley and aux shaft (3)
60510276 hose, long Top Radiator
60560822/60510278 hose, short lower/mid thermostat to steel pipe
60560859/60510275 hose, lower to radiator
60510277 hose, lower steel pipe to steel pipe
Down loaded this word doc and download cam timing template pdf and print off.
http://www.alfabb.com/bb/forums/164-168-1991-1995/46892-changing-alfa-164-12v-v6-timing-belt-water-pump.html
http://www.alfabb.com/bb/forums/164-168-1991-1995/282681-checking-alfa-164-12v-v6-engine-cam-timing.html
http://www.alfabb.com/bb/forums/164-168-1991-1995/282793-retensioning-timing-belt-mechanical-tensioner-12v-v6-164-a.html
http://www.alfabb.com/bb/forums/attachments/164-168-1991-1995/66906d1179330802-cam-timing-cam-timing.pdf 12v cam timing template
http://www.alfabb.com/bb/forums/164-168-1991-1995/446465-guide-164-timing-belt-tensioners.html#post6487817
Discussion Starter #18
Discussion Starter #19
Sending you Private Mail (PM).
1 - 20 of 38 Posts
