I had a thread here about the headlights that has gone missing. Oh well! Here I go again.
I took the headlight rings off to fix my original problem and clean them. Now I am having problems installing the driverside inner foglight ring. It looks like when I removed the ring the whole lamp mounting has moved back into the body of the car. My question is was there something holding the light mounting in place or have I inadvertently knocked the alignment out of place?
Thanks to all for sharing your wealth of knowledge.
Garrett
I suspect that one or both of the adjusting screws has come dislodged. If that's the case, it's a simple matter of lining up the groove in the screwhead and putting it back in the bucket slot. Hope the plastic nuts didn't break though
Thanks papajam,
are these the alignment screws at 3 & 6 o'clock?
Garrett
Guess I'm going thru a 'make sure to forget to post a pic' phase.:D
The 2 adjusting screws on this Carello unit are at the arrows.
