1 - 12 of 12 Posts
Got my crank pulley thanks to APE :)
i already got timing on pulley and crankshafts set, but im guessing that flywhell with its two sensors must be installed certain way as well, now i cant find anything about that in my manual (so it may seems that it does not matter) but i want to be sure before I put engine back with transmission and it will came up wrong....
The flywheel has a magnet. The two sensors then sense the magnet. Anyway, yes, the flywheel on a L-jet car must be installed correctly. In the photo below, the timing mark is near the '16' on the tape measure & the magnet is near the '10'.
Thank you Eric,
some elbow grease revealed that mark, first i though that that magnet has to be there but your picture is most helpful.
engine is ready, now just to seal-up transmission, paint the car, and voila ;)
""now just to seal-up transmission, paint the car, and voila ""
Nothing to it! Probably take about 5 minutes. I like your sense of enthusiasm. Pictures please, when you finish. Voila!
Best wishes, Robert
1988 Black Spider Veloce
Nothing to it! Probably take about 5 minutes. I like yor sense of enthusiasm. Pictures please, when you finish. Voila!
Best wishes, Robert
my "enthusiasm" duration is about year so far... :) but im still there somewhere, thinkering over my lil red car ;)
Kinda like my MGA. All I need to do is repair the body, replace the chassis & rebuild the drivetrain...
LOL I would not put that better Eric :) you hit this one right in the head! (or whatever that expression goes)
Clean, sealed, and only thing left with it to do is to replace rear mount, than ill have to fight with that pesky clutch slave cylinder (sic)
btw. awesome degreaser (combustible too) and as far as i known, plastic safe -> AdvancedAutoParts Electronic Cleaner. dont even have to scrub after....
two pics, first one: pressing transmission mount in
second: old tranny mount...
Discussion Starter #12
Huh.
Looks like you got all the use out of it that you were ever gonna, don't it.
yup, and i think that leaking trasmission its what really killed it, since now that bllack rubber feels and behaves like modeling clay :|
1 - 12 of 12 Posts
