1 - 9 of 9 Posts
Hi,
I am looking to get my Flywheel lightened, then the flywheel/P plate balanced...can anyone recommend a place/person to do this in the LA/OC area?
thanks!!
-Andy
Hi Andy - I think Stewart at APC could help with you flywheel, if you haven't done it already.
But if you already did do it, what can you really notice the difference? How do you use your car?
i'm considering it myself and would like to know how much difference it makes -
David O'D
Laguna CA
A lighter flywheel will require you to slip the clutch more from a standing start. Once moving, it will slightly improve engine response to throttle. On a street car I would not bother with it.
Umm, well, no. Having driven thousands of miles in Alfas with lightened flywheels, I can't say as I've ever noticed the need to "slip the clutch at a standing start" due to having a light flywheel. I should add that "light flywheel" doesn't equate with no flywheel in which case you might very well need to slip the clutch a bit.
I've found that fitting a light flywheel to a street driven Alfa can make a significant contribution to the overall driving dynamics/enjoyment of your car. Much, however, depends on how you drive the car. If you're a slow driving, mainly using your Alfa as a stylish commuting conveyance, then making modifications of just about any kind don't make much sense. On the other hand if you occasionally like to drive fast and hard, you'll definitely enjoy the difference when you fit a light flywheel.
Personally, I don't like lightened stock flywheels. Having driven both aluminum and steel lightened flywheels, currently I'm using an Alfaholics lightweightt steel flywheel. Typical for Alfaholics, it's exceptionally well made and fits perfectly = 13.6 pounds and US$495.
What is it about lightened stock flywheels that you don't like?
- Concern they may come apart at speed?
- Not lightened enough
- Lightened too much
If you go with an aftermarket aluminum flywheel, make sure it has a properly sized driveshaft centering bushing.
I wound up with a lightened steel flywheel from Classic Alfa. I got it in about a month ago, its great. It really livens up the motor during spirited drives, and i really feel no difference from stock when I am just cruising around town in start-stop traffic.
[/QUOTE]
I know there are good arguments in favor of machining stock flywheels, just as there are plenty of people happily running them in their cars. Nonetheless, I just prefer the increased safety of aluminum or steel purpose built flywheels to modified cast-iron.
I know there are good arguments in favor of machining stock flywheels, just as there are plenty of people happily running them in their cars. Nonetheless, I just prefer the increased safety of aluminum or steel purpose built flywheels to modified cast-iron.[/QUOTE]
Amen....the stock flywheel was designed for a 4 passenger, full tank, etc., etc., so the lightened flywheel is not road worthy is ********. If you want to do it right by a billet flywheel from Alfaholics, ClassicAlfa, etc. get the unit balanced and indexed to your PP more then likely the PP will be way off see attached...
1 - 9 of 9 Posts
