Hi Guys. I thought I should post a picture and some text about a flywheel balancing jig I have for the V6 flywheel. This was used to balance the flywheel on my 2.5 after lightening and without pulling the whole engine apart.
Basically, you bolt this to the flywheel before lightening and get the balancers to balance the jig to the flywheel. Now the unit's got 0 balance factor. Then unbolt it and lighten the flywheel. When you're done take it back to the balancers and get them to balance the flywheel to the jig which gets you back to the original balance factor.
The flange is about 12mm thick and tapped to M12 X whatever pitch bolts used. For my 2.5, the radial strip is 20X70X6mm and the other strip at the end of it is 115X20X6mm. The distance between the centre of the shaft and the centre of the latter strip is about 80mm. Surface finish on the shaft is important for the balancers- this ones surface ground, fine finish turning should be ok too.
Scott
Scott
