Just bought 87 Quad and already changed oil using Rotella T 15w40 based on this forum. Brake fluid is black and manual says to use DOT3, and I assume these brakes get bled the same as any other car - correct. Not sure what to use for gearbox and differential - see others using 75w90 for both but NS verision in one of the two areas - what is NS and why. The owners manual calls for the same fluid in both places, and for steering box. Procedure - upper filler and lower drain, loosen filler first to make sure it loosens. Getting new fluid in is a pain. Also, manual talks about greasing the slip yoke - what is this and were is it. What about changing clutch fluid - not sure how but manuals says to use brake fluid?? Thanks
