This is a shout out to all of you Spica Guru's. I have a good running Spica system that will rev up fine but the fuel pressure light is flickering.
1. Re built Spica
2. New TFA
3. All spica settings good.
4. New fuel filters
5. Revs fine but sputters under acceleration.
I am thinking poor connections to the fuel pump or possibly a weak or failing pump. The car is a 1979 and it is the original pump.:eek:
Any thoughts would be appreciated.
I'll second the fuel pump but check this first: pinch off the flex fuel lines on both sides of the rear filter, disconnect and remove the rear filter without inverting it (keep it level), invert the filter over a catch bowl (intake side down) tap firmly with a rubber mallet on the exit side of the filter (which should be pointing up) see what ends up in the catch bowl, if you find crap, you'll need to have the fuel tank serviced and replace the rear filter. Danger!since your working around gasoline, practice all safety precautions!
