Well, something had to be done about my clutch pedal being very heavy and sometimes sticking on the floor. I bought a new slave cylinder (master cylinder in AR docs) - the one for the release fork - quite unnecessarily as it turned out.
I planned to replace the two flex hoses (to the damper, and to the cylinder), but couldn't get the large nut undone where the rigid line meets the hose, under the coolant tank and tangled with the brake lines. Eventually I gave up and drained the fluid through the bleed nipple - it came out perfectly clean, and the clutch pedal pushed down with ease. So I considered that the hoses were probably OK.
I replaced the fork-pushing cylinder (my new name for it!) - which tapped out of the bracket easily, no corrosion (!) The new cylinder was quite bright 'silver' yet seemingly not plated - cast steel rather than cast iron? I gave it a couple of coats of silver paint, and painted the bracket as well. I fitted the new cylinder to the removed bracket, opened the bleed nipple, pushed the piston in, closed the nipple, and let it draw new fluid through - easy. I bolted the bracket into place.
Then I discovered that the pedal was stuck down - lifting the pedal did not bring the pedal-cylinder piston with it. So I unbolted the bracket for the fork-cylinder again, let that expand, then pushed it in sharply. That popped the pedal back up. It also produced bubbles in the fluid reservoir.
I bolted the bracket up again and discovered that the clutch was now working nicely. The right thing to do would have been to have stopped there, job done in an hour. Foolishly, I decided to carry on and bleed it.
The electric seat makes a good pedal-pusher when combined with the broken handle of a garden hoe. That way, the system was under pressure ready for when I undid the bleed nipple. All looking good, no air came out.
But suddenly the pedal became very stiff and heavy, accompanied with a 'swirling' sound, as has been decribed here before.
At this point, I decided to remove the damper - to see if it made any difference. I bypassed it just as Alfisto Steve said. That made a huge difference - swirling noise gone, and now I could push the pedal down by hand (also as Alfisto Steve said). So, problem solved. I tried bleeding the system again but I almost wonder if the system may be self-bleeding - would air find its way back up to the highest point (the reservoir) as the pedal returns? It seems that even if the pedal starts 'down' after bleeding, pulling it back up restores the system to working condition.
So I think the damper was probably the problem all along, but at least the slave, err, fork-pushing cylinder was cheap enough at US$25.
Now the last two pics. Note the installation of the pedal cylinder - in front of the pedal. That means easy access and changing it really looks quite easy, though perhaps it's tricky to get to it somewhere behind the steering rack. I think this must apply to right-hand-drive only?
The clevis pin through the pedal appears to have quite a lot of slack on my car - a couple of centimetres 'free travel' at the pedal before the pedal cylinder starts to move. The pin seems to be too small for the holes it passes through. It looks a bit tricky to remove the clutch pedal, so I guess I'll improve it a little by sleeving the pin, and leave it at that.
I still wonder, is there usually 2cm free travel in the clutch pedal? And do I need to keep trying to bleed the system?
Thanks for reading this far!
-Alex
-Alex
