Hello!
We are at the point of installing the new Pilkington front windscreen (from classicalfa.com) with new rubbers, when we fit it without the lower rubber the clearance looks tight in regard to the thickness of the rubber. See photos.
Our fitting sequence now is as follows but we are unsure if this is the best way:
1. Fit upper u profile with rubber to window on bench
2. Screw pillars with rubbers on to it
3. Hold everything in place with ducttape.
4. Lower it on to the car in to the holes in the bulkhead.
5. When and where to fit the lower rubber and chrome strip in this procedure?
What works best?
The lower rubber seems quite thick to fit below. We have the 3mm rubber gaskets fitted between the bulkhead and pillars they seem to be too thin as the glass already hits the bulkhead now.
If you have some experience or practical tips how to approach and fit this would be very appreciated so we can finish this job and hit the road!
What works best?
