1 - 20 of 83 Posts
Fitting an Alfa Romeo 164 V6 TB Q2 Differential
1 picture -new parts Q2 diff
2 picture- grash speed gear
3 picture- resin wheel speed was
4 picture- old OEM diff
5 picture- new Q2 diff
Bearing preload should be measured and shims added under the right side axle flange. Not sure how you would accomplish this with the tranny in the car though? Must have taken three or four hands to hold that diff up there, while the diff cover was installed? :eek:
Charles
Discussion Starter · #4 ·
Charles
shims rıng okey
my shims S=1,35mm P-N=1,27mm+0.08mm not yet 0.04mm
standar formula shims S=P-N+0.12mm
Fitting speedometer gear
I've been away from the forum for a while so I may have missed out on the latest news regarding the Q2 diff. When it came out in 2006 several sources said it would retrofit in the 164 tranny but that it was impossible to fit the speedometer gear on it (cars built in the last 10 years don't have mechanical speedometer drives but use ABS sensor input). Did they change the Q2 differential in the meantime, did you machine it, or what?
If you look in the pictures isn't the nylon gear the speedo gear?
Paul
Discussion Starter · #8 · (Edited)
In this post i will gather all the info about which cars you can retrofitting a Q2.
I'll edit my post as soon anyone offer new info on this matter.
If your car use a 95721110 open differentiale then Q2 ( 55208952 ) semi lock will fit to.
This is just a guide ! It is not my or AO (alfaowner.com) responsibility and we are not to blame if don't fit. This is just a guide.
picture spedometer gear- 2mm-3mm was cut
so you increased the inner diameter of the speedometer ring gear? Can you be a bit more specific...what tool did you use, how did you make sure it was straight, would it stay in place?
It looks like only some material was removed from the two tabs, which hold it in place.
Charles
If your car use a (EPER no) 95721110 open differentiale then Q2
(EPER no) (55208952 ) semi lock will fit to . Q2 diff original diff Alfa Romeo 147
Nice project, what might help is a full list of part numbers needed for this project and a write up on what exactly was done. I am not sure anyone will be doing this but if so at least they may have the proper information to use.
I may be able to pick up some of these if folks want to go in on a group purchase. This is something I have wanted to do.
55208952
7655061
46403589
5990510
Will work with 3.0L transmissions even though casing is different part number.
Jason
In the latest edition of the Danish Alfa owner magazine I saw a table of the fwd models the Q2 can be retrofitted to. This may include only models where a straight, bolt-on, fit is possible, and there could be other models where it will fit with some work, I suppose. Anyway, of 164 models, I think only the 2.0 V6 turbo was listed. I will double-check tonight.
Jes
Discussion Starter · #13 · (Edited)
old gear speedometer - no problem - standart all Alfa Romeo 164
2 nails 2mm-3mm rasping
Q2 will fit to : - Alfa Romeo Forum
Retrofitting a Q2 to an existing Alfa - Alfa Romeo Forum
Fitting an Alfa Romeo Q2 Differential
Alfa 164 ClubRegister :: Bekijk onderwerp - Q2 differentieel
Alfa 164 ClubRegister :: Bekijk onderwerp - Project 164 Q2....
The Q2 diff was built for the Alfa (really Fiat Auto) C530 transmission at a time when ring speedometer drive had been abandoned.
In 2006-07 the opinion was circulated that it would retrofit into the C503 transmission (as used in the 164) except for the ring gear.
However, looking at a picture in this thread and at
Parts
It looks like it has provisions for the ring gear (notches to hold the tabs on the ring gear). However, if the notches need to be filed down by 3 mm, doesn't this mean that the ring gear will be shifted by 3mm? How well does it engage with the speedometer pinion gear?
Jason, could the reason for the different ring gear part nos be different wheel sizes on the cars in question? Different wheel sizes may require different number of teeth on the speedometer drive if the speedometer is the same.
Discussion Starter · #15 · (Edited)
According Eper same - Eper No:60810912
AR164 2000 V6 TB = version N0 164 U.S.A. MY.91/93 (1990-1992) = version R4 164 U.S.A. MY.94/95 (1993-1994) =AR164 3000 V6 12v = AR164 3000 V6 24v = AR164 3000 V6 24v (CEE-F2)=
AR164 3000 V6 12v (CEE-F2)=AR164 3000 V6 24v Brezilya =>>According Eper same Differential =EPER No:60810912
Looks like it fits all v6 gear boxes. So this could be a really nice upgrade. I am working on pricing for all the parts I listed above.
The turbo ring is the same as the 164 3.0L which I assume he kept using. YES ademarq155??
If so this will be a very inexpensive and fantastic upgrade. At this time I am not willing to be the guinea pig...yet.
Lets see how ademarq155 pans out. Please give us all problems and please explain more.
Looks pretty straight forward looking at the parts.
Yes different part numbers are due to gear difference (ring gear). But like I mention this version he has is the same as the 164S/QV ring gear.
They are selling theirs for about $450
Here is a photo of the page from the Danish Alfa owner mag. Listed as a fit to 164 2.0 V6 TB but not the V6. According to the table it fits many (if not all) the 166 V6 diffs. I suppose it may fit other 164 diffs with some work. The author had it installed and lists cost as cost of diff to DKK 2700, retrofit kit DKK 1200, special oil DKK 350, for a total of DKK 4250 incl. something like 22% sales tax. A shop charged 6 hours for install - grand total DKK 5935 incl. the sales tax ($1 ~ 5.3 DKK).
Jes
It may just be that by "fit" it refers to a drop-in with a factory conversion kit. Perhaps you can make it fit other diffs with some effort...?
Jes
Jes
Thats what I am thinking. Those models are easy drop fit and others may need a bit of effort but not much more.
To makes things easier, ademarq155 does your mechanic know what would be needed to fit in to regular 164 V6 transmissions?
1 - 20 of 83 Posts
