1973 Spider; the daily
My right rear turn signal doesnt work but the front rear does. I already checked the bulb and the 4 pin connector. So my question is where do I find this 11 pin connector and how do I access it?
1620737
Ive followed the wires to a hole in the back of the trunk. No clue what happens after that. BeforeeI go ripping apart the whole back area I would see if anyone knows where that connector is.
Did you check the ground?
Yes I've applied power at the 4 pin connector and gotten the bulb to turn on. I'm getting no power at the 4 pin connector so I thought I would try the 11 thinking that the pin in the connector might be bad because my front right turn signal works and the front and the back split at the 11 pin connector.
Is it one of those black block
The connector is in the LH side of the car under the dash, near the foot pump for the windscreen. You might need to peal back carpet or rubber mats to expose.
Do you recall if the connector is one of those black connectors or is it a white one?
