I guess no one ever needed a vent screw?
Its okay- I machined a washer out of brass which solved the problem...
There is no way that I can see where filling the radiator and removing the vent screw will ever result in coolant to flow out without the engine running. The vent screw is higher than the radiator on the 1986 Spider, and even with the vent hole on the t-stat, there isn't enough head pressure to cause the coolant to flow up to the vent screw. Only way possible I could see is if the car sits at an angle with the vent screw lower than the radiator- a pretty steep angle.
I warmed the engine to 180 degrees F, revved the engine until coolant flowed out of the vent screw and tightened. Seems to have done the trick, but if its anything like the rest of my obsessive/manic depressive-like routines, I'll most likely take the car for a long test drive and check everyday for a week.
This all started while driving to work and I noticed the car was running hot. These were the original factory hoses! Car has about 140,000 miles. I drive it everyday. When I pulled into the parking lot and turned off the engine, I could hear a hissing sound, popped the hood and saw coolant spewing out of the lower t-stat to water pump hose. I changed the hose in the parking lot and smelled fuel from the number 1 cylinder fuel rail position. It took a couple hours to remove the fuel rail in the parking lot, called my wife to pick me up, then dropped the fuel rail off at the local Alfa mechanic's home for a rebuild, and thanked God that it didn't start leaking while driving and explode/burn up my car. Next afternoon, I installed the rebuilt fuel rail with correct material/size hoses and had her running in an hour.
So, what's the difference running a lower t-stat hose without the brass restrictor in the hose?
