1 - 12 of 12 Posts
Hi, does anyone know where I can get a copy of a 1966 Fiat 1500 cabriolet owners manual?
If that is not possible can someone answer a few basic questions please:
1. On the left side of the dash there is one toggle switch which in my car turns on the lights, there are 3 white lights, one turns on when the lights are on, and 2 are for the turn signals, and there is a red warning light that in my car seems to do nothing. Is what I'm describing correct? And what is the red light for? Pic attached
2. Under the rev counter to the right there is another toggle switch that seems to activate the hazard flashers. Is this correct? Pic attached
3. Under the dash there are 4 additional toggle switches, from left to right: Windshield wipers, instrument lights, ventilation or heater motor and the fourth one does nothing. Is the order of these correct? What is the last switch for? Is the third switch for vent or heater motor?
4. Finally, I need help attaching the hard top, I know how to attach it to the windshield but I can't seem to find a way to attach it from the back. I have attached a picture of the stainless part currently attached to the car behind the soft top base
presuming Fiat is like an alfa spider, I'd say the 2 short chrome strips presently on the car need to be removed, then replaced with special hardtop hooks....something like this (note I am not sure if these are correct, but they certainly look possible...call the guys and ask)
Like the alfa spiders too, there are probably some form of J-hooks on the sides (can't imagine just front and rear catches, tbh.)
Fiat Parts and Supplies
Thanks, that makes a lot of sense
He is correct, you need to remove the chrome and replace with the hardware that comes (hopefully) with the top.
I'll find out about the switches.
Try Fiat Parts and Supplies He always had all parts I needed (it never needed much) and might have reproduction owners manuals.
Thanks, I do believe I need the extra hardware for the hard top (which unfortunately was not included), but I talked to Chris Obert and he will be supplying me with what apparently is the correct piece...
The red light is an overheat light. Yes it has a gauge but if it goes in the red the light also comes on.
The four switches, left to right.
1. Windshield wiper
2. Instrument panel lights
3. Heater fan
4. Memory is not perfect but I believe it's the interior light. Curtsey light.
The dash lights on left, did you know their brightness can be adjusted by turning the light it's self?
I did not have the one closest to the speedo nor the one below the tachometer so it's possible that's for a hazard circuit.
I remember now the top had structural mounts that bolted on place of the chrome and then had a separate crome trim piece that went over that.
1. Windshield wiper
3. Heater fan
Thanks, you've been most helpful. The ones you are missing are indeed wired for a hazard lights in my car. And I have see at least one more car with that switch.
Just saw your pics. Beautiful. I have a 66 1500, but not nearly as nice. Chris Obert at Fiat Plus can make a photocopy of the owners manual. Also technical manuals, like the parts book. He has parts and restoration shop dedicated to Fiats. His phone number is 1 831 423 0218.
I want to know how to join in this discussion group.
I don't see any join option.
Also, what size tires are on your car? The originals may have been 5.20-14. I do not know the modern size.
Bruce Thielking
[email protected]
905 871 0121
In Fort Erie, Ontario, Canada
Bruce Thielking
[email protected]
905 871 0121
Hi Bruce,
I will contact Chris, I have bought from him in the past, thanks.
The tires in that picture were 185 70 -14, that have been replaced by 165 70 14, the 185s were too wide for the rims and car felt terrible going down the road.
I go to the Niagara Falls /Fort Erie area on business 3 to 4 times a year, I hope to be there in about a month, maybe you can show me your car.
I don't understand your question on the discussion group though.
Take Care
Bruce Thielking
[email protected]
905 871 0121
The original tire size was 145/14. My car had Michelin X tires in that size
1 - 12 of 12 Posts
