1 - 5 of 5 Posts
Sorry about the cross post, but I haven't gotten a response from the Spider Forum and I can't find an answer using search so....a three part question...
1. What is the fan belt size on a serries 2 Spider (11.1mmx84 cm?)
2. What is the fan belt size on a series 4 Spider?
3. What is the correct size for a series 2 with an alternator from a Milano?
I ask this because I have installed a new alternator in my series 2, the higher output Bosch model, and the new fanbelt I bought at Centerline is too short, it needs to be about 4 cm longer to give me enough play to adjust the tension correctly.
TIA:)
Discussion Starter #2
Fan Belt Sizes and Product Codes
I did some research and answered my own question, so I thought I would post the answer in case it is of use to anyone else.
The Product Codes for the fanbelt from a Series 2 Spider are:
Dayco 15320
Goodyear 15325
NAPA 25-08113
GATES 7320
With the Dayco and Goodyear codes the '15' refers to an 11mm wide V-belt series, the later numbers are the length in inches.
When is upgraded my alternator from the older style to a higher output model, the 65 to 75 AMP BOSCH AL16X with the built in regulator, I was able to use the fan and pulley from the old alternator and as per some previous posts had to shave 2 mm from the lower portion of the alternator bracket to avoid having the fan hit the bracket. I replaced the old flimsy wire harness from the regulator and terminal block with a single 6 guage wire from the alternator to the terminal block. The old regulator is trash. The swap also requires a slightly longer fan belt, perhaps two or more inches longer. The correct Dayco numbers for longer belts are:
Dayco 15340 - Two inches longer than 15320
Dayco 15350 - Three inches longer than 15320
I hope this info helps someone else! Cheers.
Ian:
Many years later yes, this is helpful. I need to buy one locally and needed a part number or size. I read european post of 825mm which comes out to 32.5" which matches your post.
I'm curious as to why you needed a longer belt with the new alternator when you retained the pulley from the original. I would have imagined that it should come out to the same.
Stefano,
Sorry for my tardy reply! My assumption, years later after having sold the car, is that the new alternator has a slightly different mounting configuration that added a couple of inches to the required belt size even thought the pulley was the same. Anyways, I hope my post helped!
Ian
I've got 5 NOS belts for older Alfas that I will never use. Two - 13mm x 850, two 13mm x 870 (all of these say "2600"), and one 11mm x 850. Note the width on some packaging says 12.5mm or 10.5mm because they are of different manufacturers but they all measure just about exactly the same - and will fit the pulley regardless. For example, the 11mm actually measures 10.81mm! Anyhow, five bucks apiece + cheap shipping as I can put in a Tyvek envelope for USPS. Contact me at [email protected] as I don't monitor the BB. Mr. Goose in Atlanta.
1 - 5 of 5 Posts
