FS, used , very good condition , the 1300cc and 1600cc engine, 750-101 only, from the block, the flexible oil pressure is connected to this hard line oil pressure then to the Tach's Oil Pressure gauge. There are 3 available, marked A, B, and C. Each line is $75.00 each, ask for the one you would like, if still available. Shipping is at the Buyer's expense. Please take note,...the Tach and the black flexible oil line are "only there to show" how and where these hard lines fit. The hard lines may be formed some to fit your Alfa, just don't kink the line. thanks for looking.
Hello
Do you know if does it fit giulietta sprint 59 60 with three gauges instrument?
Is the road that the hard lines do the same?
Frank
Pretty sure all 750/101 use the same hard line from the firewall to the instrument. They can be manipulated a bit to fit.
Frank, (Sampeimo), depending on your model, Spider, Sprint or SV, the under dash may have a turn or two different from the other Alfa models. And if your Alfa was restored, Tach repaired or what , and this line was pulled out and later put back, the installer may have altered with a bend or two when attaching to the Tach or the flexible line. I could check to see the lengths. Brion
