The original exterior door handles in my car worked fine, but they were pitted, so I asked the guy who built the twin spark engine to install new ones. I believe I ordered them from Alfaholics.
When I picked up the car from the interior shop, the told me that they were having problems with the driver's exterior door handle - it was stuck in the up position and you needed to use the interior door handle to open the door.
I spent some time trying to troubleshoot it today. I seem to have two different problems:
1. The door sheetmetal does not fit into the slot/channel in the upper inner part of the exterior door handle unless the door handle gasket is not installed. With the door handle gasket installed, and the door sheetmetal not fitting in the channel in the door handle, the door handle just pops out of place when you use it to open the door. See below picture for the area that's causing problems. Does anyone have any thoughts on how to address this?
2. The bracket that the exterior door handle bolts to is rusty and the metal is weak. I do not think this will fix the above problem, but it should do a better job of keeping the handle in place if it was in good condition. Does anyone know if these are reproduced?
Scott
Scott
