Looking for 101 series exhaust bracket that bolts to transmission tail housing and holds 2 bonded Silentbloc bushings. I have the other parts of this assembly.
Franklin
Thanks to Kerian and Kuni123456 for responding. After more research , I believe what I want is a 2 hole mount type for 101 gear box. I suspect the 105 type might mount to gear box but the Silentbloc bushing mounts are not horizontal or at least close to horizontal. 105 type mount has Silentbloc mounts at quite an angle from horizontal.
Does anyone have available a 2 hole 101 mount available?
Franklin
Giulietta 101 Exhaust bracket
The 105 bracket is not the same.
The correct 101 exhaust bracket to gear box is shown in the photo.
It is the same for 101 veloce or normale.
The lower rocker arm bracket is the one that varies between Veloce and Normale
Dave Brohan
Dave,
Thank you for picture. This confirms my suspicion about placement of bushings. Now all I need is a response from someone who has one available.
Franklin
Exhaust supports-
I have a few available as shown in the picture with still useable shock mounts and the long (18") straight bracket, $75.00 shipped within the US. Other brackets available and other styles of mounts too, thanks, Fred.
