59' Giulietta Spider Normale- FS, 72' Montreal, 73' GTV under Restoration, 84' Spider, 3.0 V6 Duetto
Here is a European Intake Manifold, with good Rubber Mounts, and Two Matching, oem Solex ADDHE 40 Carburetors, (tags on the carbs are 115.25.070). Although the Manifold is definitely a 2.0ltr Manifold, the Carbs are set-up for a 1300 engine, so will need to be re-jetted for use with another size motor. (jets and kits readily available). Carbs are Complete and very clean inside and out but should have "kits" installed. In very good condition. $675. plus $46. shipping to lower 48 only. Bob
