1 - 11 of 11 Posts
I am looking at converting from the Bosch FI to carbs. I am in need of a Euro Intake Manifold for my 83 Spider 2L
Be Aware: The Bosch Head, (82' on), is quite different from a earlier, "Spica" Head. The usual "Euro" manifold WILL NOT FIT onto your engine. There are later Carb Manifolds for these later, "Bosch" cars but they are Scarce. Be sure you are buying the correct Manifold. To substantiate, compare the Manifold Gaskets from both types. Bob Lesher
You are talking about the hump issue near the thermostat? I assume I need a 1983... euro manifold?
It’s not a big deal to remove the “hump” on the Bosch heads (at least when the head is off the car). If you do that you can fit the early manifolds and they are relatively easy to find.
They appear regularly on ebay.
Richard Jemison
But most seem to be Euro manifolds from the smaller engines with small port runners. A 2 liter has 36mm runners at the head side measured horizontally.
If they are 34mm they wont match up with the head ports.
I have a correct carb manifold for the Bosch cylinder head.
Price is $200 plus shipping. Intake manifold gasket and carb mounts are available fro0m Classic Alfa. And probably other sources.
Contact Karen at [email protected]
Will this coil work well with the 123 Ignition?
1 - 11 of 11 Posts
