1977 Euro Alfetta with Clean NY State title. Car was purchased from an estate approximately 4 years ago. It was off the road for approximately 12 years in dry storage. The car was properly brought back to running condition with new carb kit, tires clutch master/slave/hydraulic line. Brakes and coolant system flushed with some new coolant hoses. Rear tranny and engine mounts. The engine runs great with 170/180/170/165 compression. It is fitted with a header and a performance exhaust system. Koni shocks. Everything - including all electrical systems were working on the car when in use. Car has been on the road for approximately 1000 miles.
Unfortunately the rear flex joint failed and tore up the trans-axle clutch/transmission castings.
This was a father/son project that lost momentum last year and the car has been off the road since. Lost storage so the project is up for sale. Trans-axle is currently out of the car.
As far as Alfetta's go this is a VERY nice car. Cloth interior has some wear on the drivers side bolster but balance looks good. No corrosion around the windows. Some corrosion in the inner front fender panels - about 1 1/2" by 5" . All jack points solid.
When running tranny had no sycro issues and the engine ran very strong with the Euro spec cams and carbs.
Can send more detail pics for those serious.
Selling for the owners. Car is located south of Rochester NY 1 mile from the NY State Thruway and Rt 390 intersection - easy access.
Like to get $2800 for it.
Spare parts available if required.
Chris
Winners Race Prep
585 330 5456
[email protected]
Nice looking car, except not fond of the flat black hood. Like the cloth seats. Also, the front suspension needs to be set back down to the proper level. Did this for our Alfettas, both the GTs and the sedans, and it made the cars look proper at the European height, not the US requirement for headlight rules, which is too high in the front.
Looks like that casing could be welded and cleaned up.
I sold RJ 6 or so Alfetta transaxles. He makes the close ratio gearboxes out of them for the V-6's. Most of them were complete. He might want to sale the clutch units off of them.
Transport
Its still on the trailer in storage the storage facility....
Transportation can be arranged after inspection and payment.
Chris
Neat Project
Neat project - needs to go to a new home.
Make me a reasonable offer....
Chris 585 330 5456
