Took out my car for the first time Saturday at the track. After 4 laps my gas pedal got stuck.. engine reved up to the rev limiter for maybe 5 seconds before I shut the engine off.
I tried to restart the engine and noticed that the fuel pump was running when I turned the ignition on without turning the engine. OK double relay is fried, indeed. The right side relay was shut closed.
So I changed the relay, now the car starts for 3 seconds or so and then shuts down. I have spark, fuel delivery is OK at the rail put I don't think I have enough psi. (Will have to check with gauge). The air flow meter seems to be working fine.
Could this have fried the fuel pump or the computer?
Did anybody experience the same problem?
Thank you for your help.
