I took my 88 Alfa out for a spin this evening and as I was coming home the engine cut off as I was coasting up to a stop light. I rolled into the gas station nearby and tried to diagnose the problem. My first guess is the fuel pump but I could hear it cycle when I turned the key on/off. After sitting a bit I tried to start again and she started but cut off immediately. I got out of the car and opened the fuel tank and there was a substantial vacuum. Got back in the car and she started up without any problem. I put some more gas in just in case and she only took about 6 gallons. I drove home (about 2 miles) without any more issue and I could hear the in-tank pump running as well as the one under the car.
(Also of note, I had just driven on the interstate for several miles at 70+ mph and then the road where I stalled was around 50+)
Could too much vacuum be the culprit? I checked the one way valve when I got home but there wasn't any vacuum in the tank at this point.
Another also of note: I'm running a Megasquirt fuel injection system and I mistakenly had the logging turned off... so nothing to see there.
Thanks!
Adam
That would be my first guess. There is a one-way valve and an air inlet valve inthe vapor recovery/tank venting system. They can get gummed up and act as no-way valves. Squirt some carb cleaning spray in them and blow them out until clear.
Another guess would be a failed in-tank pump or faulty stepped hose. When the fuel level is below ~ 1/2 full the main pump will struggle if the in tank pump is not supplying fuel. A faulty stepped hose will cause the main pump to suck in air when the fuel level drops.
1626119
1626120
1626121
to test the intank pump
Lift the carpet and that rubber protection thing to get at pump spade connectors.
put a wire straight from the battery plus to the middle spade (that is the pink/white wire)
and from the battery negative to the separate ground spade (black wire)
you should hear it hum along nicely
