Hey Guys!
My '86 GTV6 runs pretty well... that is under 4500 RPM... then it sputters and will not deliver additional power until I shift. This happens in all gears and always around 4500 RPM. Help!
Thanks!
Check your timing. And look for a vacuum leak. Extra air would cause it to run lean and stumble and also increase the idle.
Sent from my ONEPLUS A3000 using Tapatalk
Yes... been going thru the car taking care of leaks... had a few in the exhaust system including a loose manifold bolt!
Haven't checked timing yet... I need some help with that one! Thanks!
