Thanks quadrifolio As per your information it is a 1600you must look at the front of the head and you will see a casting mark, and with this table you can define your engine, I hoop it helps, cheers
Hello Brian,you must look at the front of the head and you will see a casting mark, and with this table you can define your engine, I hoop it helps, cheers
