Be sure engine is cold. Remove the radiator cap. (no coolant pressure) remove center nuts. Add special hardened thin washers over installed bracket studs. Oil stud threads LIGHTLY, Install nuts and retorque using cold torque figures. You should be fine. A warm re-torque after driving a bit is a good plan. Retorque all, with radiator cap removed.
