Looks close enough by pictures.
Just looking at the photos on ebay, that Fiat component seems to be more than a resistor; notice the smaller cylinder below / at 90 degrees from the larger (green) cylinder. What do you suppose that is? A thermal overload switch? Diode to dissipate the flyback voltage when the fan motor gets shut off?
I'm not suggesting that second component will cause a problem, just pointing out that it's something different from the 164 resistor.
