21 - 35 of 35 Posts
Discussion Starter #21
dang
i am bummed about this. i bought a new compression test kit. and the compression seems okay now.
i really just wanted to know why the car runs so bad, bad rings would of at least given me something instead of just throwing money at this stupid car.
first pic is cold the second is hot.
so....
rebuilt the carbs,
new distributor and coil
good compression
should i still check the cam timing?
this thing is too much
Rebuilt carbs? I'm going guess the carbs are out of sync
New distributor, are you sure the timming is right?
It sounds like you have what you need, putting in new rings would be throwing money away.
Here is a good article on setting the carbs, Daves home page
Which carbs are you using - the full model number?
It would probably be useful to define what the motor is doing:
Hard starting?
Rough idle? Rough running at certain speeds? At All speeds?
Lacking power at certain points?
Backfire out exhaust?
Backfire out of intake?
Is it worse cold, hot or all the time?
Blue smoke?, white smoke? Black smoke? No smoke?
Water in oil? Oil in radiator? Oil leaks around the head?
I'm sure there are plenty of other maladies, these are just off the top of my head.
If you can make a youtube video and post it, it may help in the diagnosis.
Sounds like you just need some tweaking and not a lot of money. I know this is not a SPICA motor but I find it interesting when you are dialing in the FI pump that as you go the motor runs crappier and crappier until the final twist of the screw driver and then every thing falls in place and it runs fine. Unnerving in the process though...
Discussion Starter #26
carbs may indeed be out of sync. i need a sync tool and that link will be of great use, thanks
i believe the timing is right
full number? i don't remember dcoe 40s xxxx....
Maybe your cams are flat......
interesting thought, i'll post some pics
Hard starting?
yes i should of said all this first, sorry
hard to start cold, rough idle, uneven idle, will go up then die down.
lacking power when you accelerate, also a large bog if you floor the gas pedal.
backfire out of intake, and i retarded the timing from the mark and it runs a little better.
no smoke, no leaks. here is a video of it running
thanks for the help everyone, and the shoulder to cry on :crying2:
I am joking about the cams, althou some here think all Alfa cams are worn.
This method of trouble-shooting is the least likely to get results as there are so many opinions to check.
On owner went on for a long while checking and replacing parts until he found that the exhaust pipe had been filled with acorns by an industrious squirel.
Do a proper trouble shooting method. System by system as a pro would do.
Discussion Starter #28
okay, checked the cam timing marks. i am assuming these are them and they are on at TDC.
i ordered a carb sync tool, so the carbs may still be out of tune here but here are some videos of the car running, the idle gets really fast after the car has warmed up, but like i said, we will see after i re-sync the carbs
Have you checked for air leaks in the rubber carbie mounts?
This will definitely make the car run like a dog when everything else appears ok.
Wazza.
Discussion Starter #30
Wazza.
i did a visual check before reinstalling the carbs. they seemed good, but i did not take them off the car to inspect. is there a way to test them? how do they come off?
Discussion Starter #33
You can check for air leaks by spraying starter fluid around the mounts. Some use propane gas. If the motor speeds up you likely have a leak.
okay, this may be something. here is a video of the test. it is hard to tell because of such funky idling but maybe....
The theory of introducing some flammable gas into the intake manifold works. We recently did exactly that and appeared to find the culprit with the soft mounts. New soft mounts and $120.00 later the loping idle and lack of a decent reading with our vacuum gauge leads me to believe the starting fluid test did not perform as intended. Not sure where to go from here, has anyone had luck with the "smoke test" for vacuum leaks in the intake system?
Yes, we are off topic
The problem with starting fluid is that it mostly evaporates before reaching the suspected vacuum leak source. I use brake cleaner or carb cleaner. You can use water if you like. You'll know when it hits the leak......
21 - 35 of 35 Posts
