1 - 2 of 2 Posts
1976 Nuova Super. The wiring for the engine compartment light was completely missing ... part running up side of hood to the light.
There doesn't not appear to be a hole to feed wire through so is what I did right? .... see attached photo. The switch is in the middle left of the photo.
I have only cars with the center strut light. Can you show where the light itself is? This seems right, that the ground wire would clip into little tabs, running down to the ground switch.
1 - 2 of 2 Posts
