I just replaced the internal pump and the in-line fuse to the pump. I gave it a regular tune-up including new battery. When I turn the key from OFF to ON, usually nothing turns on. If I constantly turn the key back and forth from OFF to ON, sometimes I'll get lucky and the electrical system will kick on. If I turn the key to START, I guess the Starter, begins to turn the engine, and everything sounds like it is trying to start, except there is no gas getting into the engine because the pumps aren't getting any power because the electrical system isn't on (which also makes me assume the fuel injectors aren't putting any fuel into the valves). Even the few times the electrical system is on and I try to crank the engine, it still won't start. I think the injectors might be bad or the ECU isn't kicking on (but I measured 10.6-11 volts during cranking (which should be enough, right?)). I just can't figure it out. Any help?
