1 - 5 of 5 Posts
Help, drivers window doesn't' go up /down, tried switching switches with the passenger side and still not working, any help with tracking wiring would be appreciated, btw has anyone ever removed the motor and regulator and put back without wanting to jump off a bridge?
May we assume you have checked the fuses? (but I think there is one fuse for both windows so if the passenger side is working that rules out a blown fuse...)
The most common place for a wiring fault is inside the rubber accordian at the door hinge pillar. The frequent flexing of the wires can cause a break.
on the drivers side the polarity using a multimeter should switch at the motor terminals as you switch between up/down modes. Wire color should be yellow and yellow/black from what I remember.
1 - 5 of 5 Posts
