41 - 49 of 49 Posts
hello,
Has anyone installed a Go-tech mfi pro ecu to manage a twin spark? if so, can you share your map? it will likely be better than starting with a default map. thanks in advance for the help.
andres
Discussion Starter #42
Has anyone installed a Go-tech mfi pro ecu to manage a twin spark? if so, can you share your map? it will likely be better than starting with a default map. thanks in advance for the help.andres
Yes, the South Africans have done several - email Louis at GoTech and ask him for a map from Domingos. Uwe Becker at Omega Motorsports in LA also did a MEAN TS in his 105/115 GTV and he runs GoTech - as him maybe!
incorporate the additional cam-sensor at the rear of the head to run full-sequential!
hi,
how did u mean to do this? is there any parts from another car u can use or u have to fabricate the wheel, bracket, sensor hole... etc...? thread the cam?
have u done this already, have any pics of the setup?
thx
41 - 49 of 49 Posts
