You know what Im talking about...the BOSCH ignition spark advance box.
What are its inputs? meaning does it share any of the sensor inputs with the L-jet? I know of at least one input...the one which is supposed to be disconnected
on the t-stat housing. Or is this thing just basic-basic.
What is this thing...BOSCH EZ-L or knock sensor-less EZ-K? or something Milano specific
It has a 24 pin 'chip' inside...anybody know whats on it? does it have a RPM X ignition advance map on it or RPM X load X advance? I know it has a RPM limiter somewhere in it...hardware or software controlled?
I know that its not worth keeping if real control over ignition advance is wanted, but im just a curious monkey...
now...ive read things in the past about knock sensors and the 12 Valve engines. Some say NO others say YES...any consensus? Is the engine entirely too noisy for knock sensors? generally knock sensor systems will only listen for knock during spark events, but is the engine still too noisy?
Id like to install an ignition system which will advance the timing based on a programmable map, as well as knock conditions, so Id like to know if its possible on the Alfa V6.
