I am looking for a Bosch connector to fit the early 81-83 gtv6 dizzy. I am in the final stages on my 87 spider w/ 164s 3.0 swap. I am using the Bosch bim024 ignition module and no fuel injection, 3 Weber idf 40’s on fabricated manifolds. Just trying to find the right connector to finish the ignition. Thanks!
Possible solution. I noticed the internals of the Bosch ev-1 plug looked like it would work. I cut up a replacement and after some sanding and filing it made a nice snug fit. Since I wouldn’t be using the braided shieth I tightly twisted the 2 leads. Time will tell if it works
Hello all I just purchased a 1989 Spider Qudrifoglio. The car has been sitting for 16 years I dropped it off at the mechanics we did a tune up changed fluids refurbished the gas tank and fuel sender and the car feels gutless and won’t rev freely. Has anyone had these problems on there Alfa ?
Howdy peeps, my apologies if I've posted this thread in the wrong place. Mods, feel free to move it around if needed.
I've converted my EFI 1985 105/115 2.0 Spider to carbs - Runs great! But the car is still operating with both the Bosch ignition and fuel ECUs hooked up. I would like to remove...
I posted this in the Milano / 75 forum, but not much response so I thought I'd try here: It's been a while since I was on this forum; so long that I've been forgotten and had to re-register!
Anyway, I'm in the process of resurrecting my old hillclimb 75, and I'm having some problems which...
I just bought this car that needs to be put back together. My son and I are going to use this car for Auto X and we are wondering how the engine will stand up to this kind of use. It is mostly short tracks and probably wont get out of 2nd gear. Thanks for any and all responses
Im patiently waiting for my NoDiz to control the ignition of my TS conversion: NODIZ Pro | Standalone Ignition Only ECU trying to jump on the learning curve
Im using the standard 60-2 Triggerwheel and Bosch VR Crank Angle sensor & mount from a Milano/164
69alfa has posted this very...
