One wouldn't think there could be five questions regarding the reservoir, but...
1) - Are these reservoirs soldered or just crimped? Or - has anyone had theirs powder coated with no problems?
2)- Pray tell how does the fluid get from the bladder to the brake MC? The bladder appears as if it is sealed except for the vent hole in the cap.
3) - I always leave the reservoir's cap off when bleeding the brakes. Should it be on when bleeding the brakes?
4) - Is the nut holding the center hollow unit soldered on or does it have an aluminum washer?
5) - Is the bend, with notches cut out, normal on the steady bracket (lower right)?
