Thanks to Randy(101/105guy) for highlighting the need for the rubber diaphragm that seals the lid and keeps the moist air away from the fluid. He first provided the information in Bruce's thread about his amazing Super here
The reservoir that was used on the early dunlop brake 105 series cars (Ti, Sprint GT, early Super etc) does not have a maker's mark. It should have a rubber diaphragm inside it.
Sorry for the photos of a dirty reservoir but I havent 'restored' it yet. Soon!
The diameter at the bellow part is 65mm, just small enough to fit through the opening of the reservoir
Gavin has been able to provide the parts numbers for the Girling diaphragm which should fit the Dunlop brake correct reservoir.
Another thing to help minimise brake fluid spillage(nasty!) is to make sure there is a rubber o-ring fitted to the bottom connector. See this thread.
If any info is incorrect or you have more to add to the discussion, please do!
Brake reservoir diaphragms. These are available in Australia from Earls Performance products: Earl's Performance Products Australia - Home Email: [email protected] Ph: 61 2 9748 6011. Talk to Martin Fell. The Girling part number of Moisture Barrier Diaphragm to suit large reservoir is 64478356 (the reservoir on the left in photo). This reservoir has a diameter of 76mm (2.99 inches) so the diaphragm will suit the reservoirs used for Dunlop and ATE brake systems. The outside diameter of these, measured at the thread is 3 inches (78mm). Incidentally the original Alfa part number for what they called the "Moisture Separator" was 105 14 45 536 01. The Girling diaphragms are compatible with all modern brake fluids. Gavin
