21 - 23 of 23 Posts
Discussion Starter #23
Couple of tips. Download the graph to your computer and resize until it fits the trunk trapezoid. I used 79%, but yours may be different. Measure many times.
Big tip, make sure the script, which is MALLEABLE, is in the position wherein you like the morphology before you mark the peg positions. Another tip, use sharp bits and rotate your drill backwards to have the best luck at not incurring a big paint chip. After you have hit metal then you can carefully drill forwards.
This procedure may cause cancer in the State of California. Please use goggles, gloves a respirator and have an assistant available to call 911 if you make a mistake and freakout.
21 - 23 of 23 Posts
