1 - 5 of 5 Posts
On a '69 Spider, what is the best way to remove the small hubcaps without scarring the wheels?
Once you get your hubcaps off, it helps to spray a little silicone or WD-40 on the three wheel humps before re-installing. This both makes the next removal easier, as well as retards rust where the hubcap scrapes off the paint.
Also, it is not necessary to use the palm of your hand and 'hit it' to get it back on. Just push it on, steady even pressure should do the trick. These are pretty easy to dent, you know the rest.
1 - 5 of 5 Posts
