I just lost the illumination to my tachometer...... any good advise or procedure in removing/installing a new bulb. I assume I need to contort my arm and hand from under the dash to the back of the tach ? Top.... bottom ?
Any advise is appreciated.
Bob
I find it easiest to push the seat back as far as it will go, then lie down with your back on the floor mat and reach up from there.
i'm pretty sure they push in, so yep contort and pull holder from behind. there I a bit of space there
There are two light bulbs (red insulators), one next to the generator warning light (white insulator), the other one will be on the opposite side. Perhaps one bulb was already burned out if you lost all illumination?
1628101
