181 - 197 of 197 Posts
You need to do the roll pin update. If not you will start to get oil seepage at those spots in a couple of years.
Thanks Craig. I bought the roll pins from Jim G already. They’ll go in next. I’m just gathering all the info I may need before crushing the new gasket.
Regards
Mark
I forgot it was you that I sold them to.
Discussion Starter #183
Yep roll pins go in next Jim, thanks! Just wondering if I need to put sealant at the rear of the head gasket where the middle oil drain passage in the block is covered by the head gasket.
Discussion Starter #184
Coming together! The head went on smoothly. I put a bead of anerobic sealant on both the head and the block between the water jacket and the oil return holes at the rear of the engine as was suggested. The timing chain took a couple tries to get right but ended up dead on in the end. Waiting on a lower oil pan gasket and a speedi sleeve for the crank pully now.
Mark
Don't forget the rubber square that goes in the upper pan.
Discussion Starter #187
I made a blank off plate for the rear crankcase vent using the vent fitting as a template. I cut it out of 3/16” steel plate and sanded the mill scale off one side using 80 grit sandpaper flat on my vise’s anvil.
Discussion Starter #189
More Progress...slowly��. I had some down time waiting on a couple of gaskets so I sprayed the engine compartment again; I just didn’t like the color match after the first attempt. I received the gaskets and installed a few more bits installed today though! I should be able to marry the transmission to the engine tomorrow and maybe slide it in!
Mark
Discussion Starter #194
I think i’ve Read a couple of your posts regarding the restoration. That’s going to be a beautiful car. I may like to find a body someday and do another full restoration, then swap the parts out while cleaning, painting, and plating as I go; but I don’t want to take this car apart for several years and not have one to drive. It’s too much fun!
Regards
Mark
