Ken is right that the banjo set-up needs a 4-rubber pad set-up rather than the GTA 3 pad set-up. It is available with AN fittings - 6045-40 is described as having D-06 which refers to dash 6.
Interestingly enough, I do have a set of Bendix pumps with original GTA fittings that also are spaced apart for a 4-pad set-up. I am not sure what car it came from, but a TI Super or TZ-2 is a possibility.
Hi,
I am trying to reproduce the 2 fittings used for GTA.
Can you take some dimensions for me from the fittings that you have.
The tube diameter? 5/16 ??
The hex head size and the Pipe thread of the pipe fitting?
The dimensions from centre line of the pipe fitting to the end 90 deg tube.,
The dimension from the end of the pipe fitting to the centre line of the 90 deg bend.
Bend radius? The 5/16 tube bender I have produces about a 0.5" radius to the inside of the bent tube.
The location of the tee branch.
Are the dimensions of the single tube the same as the tee except for the tee branch addition? I expect they are.
Is it a silver brazed or welded construcion??
Zinc plated?
Bulge on tube ends? I figured out how I can do this.
I think the tubing is 5/16" dia and the fitting is 1/8 npt.
Ciao
Ken
