motor/transmission bushings? I`m assuming that if it vibrates on neutral, drive shaft with his doughnuts is ok.
motor/transmission bushings? I`m assuming that if it vibrates on neutral, drive shaft with his doughnuts is ok.Hi all, I need help diagnosing a vibration that I can feel (and see) in the shifter of my 91 Spider. It is there most of the time though it sometimes seems to smooth out, come and go. It is there whether in gear or in neutral and seems to increase with speed. It isn't real bad but I would like to fix it if possible.
I recently had the rear end replaced (had a clunk) and the vibration seems about the same with the old and new units. I have new motor mounts, the engine runs pretty smoothly and I have replaced the sway bars, tie-rods, springs, shocks and nearly all the body bushings so it rides very smoothly.
Any help would be appreciated. Thanks, Pat
