I am looking for a good condition used driveshaft for a ’79 Spider. My driveshaft has seen better days as the transmission olive has worn through the bushing and into the driveshaft itself!
So at a minimum, I prefer the driveshaft to have a good front bushing. Ideally, a plug and play driveshaft would be perfect.
Would also like the eight (8) driveshaft bolts too but these are not so critical.
Shipping to 47203.
So it sounds like you only need the front driveshaft - not the rear. Alfa Parts Exchange probably has a mountain of them.
So you want both the front and rear sections? (The rear is a two piece assembly that has two u-joints, the front has the carrier bearing assembly.)
You also want the bushing that fits in the flywheel?
What about the rubber donut?
Discussion Starter · #6 ·
Yes, I would like both sections (F&R). I am trying to weld up the one I have but this will take some time. Plus I would like one for a 'spare'.
I have the tophat and doughnut already. Good call on the bushing in the flywheel as I have not checked this but should be okay since the front part of the mainshaft looks good.
Chip
