I am looking for information regarding driveshaft angle between engine and transaxle in a GTV chassis.
I am in process of building tube chassis based on GTV 6 chassis but have moved engine mount back 11".
Is there is reference available that indicates what driveshaft angle should be ?
Thanks for any info.:)
Richard Jemison
Shaft alignment
The best location is so that the engine crankshaft is aligned with the inputshaft of the TA with no angularity.
Agree, the angle should be 180 deg. So if the engine is mounted higher than the transaxle then you have to tilt both so the drive shaft is in a straight line.
In the process of building a tube chassis and no pictures on the BB? I'm sure I'm not the only one that would like to see your project.
